Long term 2011 F-250 fog light upgrade solution? >
Old 01-21-2017 | 08:05 AM
SANLEONKID's Avatar
Default Long term 2011 F-250 fog light upgrade solution?
I purchased a few sets of the Chinese 100W replacement bulbs. Great prices, look good but only last several months. I have extra bolt-on high intensity but like leaving the built-in's on for regular driving. Anyone have luck with any of the newer upgrades out there? I would like to stick with OEM plugs.
This is what I've been putting in
https://www.amazon.com/100w-Light-Xe...ight+bulb+100w
SANLEONKID is offline
Old 01-21-2017 | 01:00 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Buy some LEDs from Rigid Industries.
http://www.rigidindustries.com/vehicle/ford
Expensive, but great products.
Sydwayz is offline
Old 01-21-2017 | 07:30 PM
SANLEONKID's Avatar
I have a set of Dually XL 3x2's hooked up to uplifted switch for ranch/late nite driving..... I'm looking for driving ones to go in the built in fog light slots.
[ATTACH=CONFIG]564019[/ATTACH]
Attached Thumbnails Long term 2011 F-250 fog light upgrade solution?-front-end.jpg
Old 01-24-2017 | 11:35 AM
I swapped my stock fogs out for the rigid Duallys. I also have amber clip on lenses for rain and snow use
tdbrickndirt is offline
Old 01-24-2017 | 05:25 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Exactly what I was referring too. I really like those single LED strips that "finish" the grill too. But damn does all that get pricey fast!
Sydwayz is offline
Old 01-24-2017 | 08:29 PM
SANLEONKID's Avatar
Don't you get flashed from using the dually's? I'm looking for every day running lights that are just a bit brighter than stock.
Old 01-24-2017 | 09:19 PM
Yeah I agree. Definitely a little expensive
Old 01-24-2017 | 09:21 PM
I angled them down a little bit. I do get flash every once in a while but I think it's bc I put hids in the headlights and the truck is leveled
Old 01-25-2017 | 07:05 PM
You can put a "volume control" on the LEDs and reduce their perceived brightness. One of my LED sets of lights for the rally bike has that; 30% on dims and 100% on highs.
Really do like the look of the strip in the grill and think one on the top would make it perfect.
Chart is offline
Old 01-25-2017 | 07:20 PM
Thank you. I originally was going to put one on the top but the shop I used talked me out of it. I forget the specifics but the top of the grill requires more airflow than the bottom etc I agree it would look nice though
