Offshore mounts tie bar trim pumps ect >
Old 01-24-2017 | 05:49 PM
Sick Stinger's Avatar
Brotherhood #1
Default Offshore mounts tie bar trim pumps ect
I have a set of off shore mounts for a bravo out of a 38 formula 400 shipped for the set
2 bravo 1.36 drives. Gears look good guessing 500 hours as that's on the clock
One is a LWP other is std. Lwp lower is tight to spin believe is the shaft seal not sure. 1300 lwp 1100 std
Latham tie bar 35 center 150
Gil 24 boxes ( I believe) 60 for both shipped
25P mirage solid hub props 350 shipped decent shape in no way perfect.
Trim pumps plastic res bottle 150 shipped have 6
Bullet style 150 shipped have 4
Square bottom have 6.
I will get pics for any one that wants them.
Sick Stinger is offline
Old 01-24-2017 | 08:33 PM
whiskeyhangover's Avatar
May be interested in the tie bar. I'll need to measure
whiskeyhangover is offline
Old 01-24-2017 | 08:49 PM
Does it adjust?
Old 01-25-2017 | 05:56 AM
Brotherhood #1
Has adjustment yes
Old 01-25-2017 | 06:59 AM
Will it fit older style bravo 3's?
Old 01-25-2017 | 07:14 AM
Brotherhood #1
Yes the saddles are all the same.
Old 01-25-2017 | 07:21 AM
Ok. I'll see if I get to where the boat is today and measure it. Thanks
Old 01-25-2017 | 07:23 AM
Brotherhood #1
Not a problem.
Old 01-25-2017 | 03:55 PM
Center to center on mine is 38.5 will that work?
Old 01-25-2017 | 04:25 PM
Brotherhood #1
I will check,
