Adjustable guide plates >
Old 01-25-2017 | 06:51 PM
Default Adjustable guide plates
Any preference btwn dart and comp. They look pretty much the same. Also any known issues or precautions using these. Any mix matches on build with using std plates and adjustable plates. I'm just trying to get as much in advance as I can for builds. Thought about getting a set of the traditional non adjustable comps and set of adjustable.
getrdunn is offline
Old 01-25-2017 | 08:08 PM
Why would you get 2 different ones? I'm also curious on replies to the adjustable guideplate thing.
Crude Intentions is offline
Old 01-25-2017 | 08:10 PM
I seem to always get the darts,,they work great,beats cutting and welding the stockers.
sutphen 30 is offline
Old 01-25-2017 | 08:11 PM
i use the dart ones,easy to use and easy to follow directions.
mike tkach is offline
Old 01-25-2017 | 08:13 PM
i used to cut and weld in the old days.it sucked and took a lot of time.
Old 01-25-2017 | 08:24 PM
I'm building two engines and have seen in cases where a std non adjustable might work fine depending on what int and exh and others that needed help in the same engine. Ya I know sounds messed up but true.
Darts they will be.
getrdunn is offline
Old 01-25-2017 | 08:37 PM
Lee's Avatar
Lee
Dart, Make sure to Loctite them.
Lee is offline
Old 01-25-2017 | 08:38 PM
If your doing any new rebuild even with stock cam etc they help alignment big time. BBC has issues from the start as it is.
getrdunn is offline
Old 01-25-2017 | 08:42 PM
i use leak lok on the intakes and oil on the exhaust.
Old 01-25-2017 | 08:46 PM
No doubt.
getrdunn is offline
