Aluminum and Ford corrosion issues? >
Old 01-26-2017 | 06:31 AM
Default Aluminum and Ford corrosion issues?
Seeing how Ford is struggling with corrosion issues on their aluminum hoods on Mustangs and Explorers how are their aluminum body pickups going to fair?
For those of you that don't know about the issue. The aluminum hoods have corrosion bubbles popping up around the edges of the panel. Ford covers this for 3/36K but the issue usually pops up in the 4-5th year of ownership to which Ford argues since it is not perforated (swiss cheese hole) then it isn't an issue they cover.
With aluminum body pickups this is probably going to become an issue faster due to the rougher use conditions those trucks will encounter.
Jupiter Sunsation is offline
Old 01-26-2017 | 08:50 AM
Oh that's fun. *looks at two week old F-150*
Captain YARRR is offline
We are a 400-500 unit a month ford dealer and have not seen any yet. We are worried forsure!
indysupra is offline
Old 01-26-2017 | 09:06 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Ford has been using aluminum body panels for years for over 10 years, specifically on the Lincoln line they have been using hoods and trunks. I have not seen this issue in the past; but perhaps the new alloys are causing the problem. Any more insight or pictures? I have been eyeballing 2017 Fords, and this may be another sway away from them (for me).
Sydwayz is offline
Old 01-26-2017 | 09:53 AM
Knot 4 Me's Avatar
I'll let you know in 4 years.
Knot 4 Me is offline
Old 01-26-2017 | 11:39 AM
Google explorer hood corrosion and that should pull up the issue we have had.
Old 01-26-2017 | 05:50 PM
In 2004 the manufacturer sent dealers a technical service bulletin (TSB) about bubbling and blistering under the paint on aluminum body panels due to "iron contamination of the aluminum panel".
The TSB goes on to say that "testing has revealed that the aluminum corrosion was caused by iron particles working their way into the aluminum body part, prior to it being painted."
pics here: http://www.fordproblems.com/trends/hood-rust/
Old 01-26-2017 | 07:02 PM
Sand, treat,prime,base,clear and repeat in 5 years
1989mach1 is offline
Old 01-26-2017 | 07:52 PM
I have a 2013 Explorer with rust bubbles.....never been hit, no snow/salt/bought it new. My buddy of 30+ years is a Ford service writer and he said they all do it and his personal Mustang has the same issue. So the repeat in 5 years isn't possible....repeat in 3.
Sure glad it has the 3 stage pearl paint they offered in the Limited trim!
Old 01-26-2017 | 09:20 PM
Yes that one is fun to paint for shure but look at the bright side every time you fix it the blend will go bigger and befor you know it will be a fully restored....
