Did they ever make a 350 Vortec engine with a fuel pump boss? >
Old 01-29-2017 | 03:12 PM
Default Did they ever make a 350 Vortec engine with a fuel pump boss?
I am doing some research and have not seen one yet. Need to change out an engine I bought in a boat that the engine was put together by a hack. The block is not worth saving, both heads have cracks.
1BIGJIM is offline
Old 01-29-2017 | 03:23 PM
Many were/are drilled in the aftermarket. If you buy a reman or crate motor with a "seasoned" block, odds are it will be drilled.
TxHawk is offline
Old 01-29-2017 | 03:52 PM
When I rebuilt my 350 it had a mechanical fuel pump which fed the VST. I had to pass over several blocks that had issues OR did not have the mechanical fuel pump pad. I purchased a new block from GM that had the mech fuel pump provision.
Bottom line is both style blocks are out there. You just have to search a bit OR buy new.
Trash is offline
Old 01-29-2017 | 09:53 PM
98 chevy 350 out of a half ton not drilled.
98 chevy 350 out of a suburban was drilled.
so yes as these were original stock motors.
Mr Maine is offline
Old 01-30-2017 | 07:32 AM
have one on engine stand now, late model for roller cam, has mech pump
ezstriper is offline
Old 01-30-2017 | 12:41 PM
I have seen some of the pcm mpi vortec motors with pump block off plates. Cant think of a roller cam vortec v8 that went over to the truck world that wasnt fi though.
Better check your camshaft 8 digit p/n too , if things are that bad with what you have there
airjunky is offline
