525,600,700 header gaskets >
Old 01-30-2017 | 03:32 PM
F-2 Speedy's Avatar
Default 525,600,700 header gaskets
Are you guys buying Mercury ?? or what
thanks
F-2 Speedy is online now
Old 01-30-2017 | 04:01 PM
I use Fel-pro
class6 is offline
Talk to Eddie Young he has some
midwest272 is offline
Old 01-30-2017 | 04:03 PM
I use cardboard and Kopper Kote.
Baja Rooster is offline
Old 01-30-2017 | 05:54 PM
Its a different pattern on the Edlebrock alum heads. Its not standard big block. Does fel pro make them?
fossil fuel is offline
Old 01-30-2017 | 06:21 PM
525 efi heads??
phragle is offline
Old 01-30-2017 | 06:54 PM
Originally Posted by phragle
525 efi heads??
yes 525 boltpattern... 525s are a spec head from Edlebrock if my info is correct
adk61 is offline
Old 01-30-2017 | 07:02 PM
The merc gaskets are the ones we use ,if the headers have cool collars the mercs can handle the heat a lot better than the rest they also have a different bolt pattern than the stock bb
MDGperformance is offline
Old 01-30-2017 | 07:35 PM
F-2 Speedy's Avatar
I was seeing if someone else had re popped these,
Old 01-30-2017 | 11:51 PM
We have some MLS stainless steel gaskets made for the 525, 600,700. They are lifetime gaskets. You can not hurt them. If the header loosens, the stock gasket will push out. You then have to take the header off and remove the gasket and replace it. Mercury gets almost $60 per set. Our gaskets are a little more, but they will last forever. If the header comes loose and starts to leak exhaust gases, just tighten it back it. You WILL NOT blow the gasket out. They are $85 per set and worth every penny.
Eddie
Young Performance is offline
