Moisture in valve cover >
Old 02-02-2017 | 05:41 PM
Default Moisture in valve cover
I have a 96 mercruiser mpi 502. I am getting moisture in the valve cover and milky sludge coming from the vent tube goin to arrestor. There is no trace of water in the pan or on dipstick. What could cause this? I changed the thermostat boat holds at 160. Also while getting on plane I'm noticing a lot of a steam from exhaust. Any help would be great thanks.
Boosted502 is offline
Old 02-02-2017 | 06:04 PM
cigrocket's Avatar
Cold water, condensation, once oil gets hotter then 212 the condensation will burn off. You can solve with oil thermostat, but really not needed.
cigrocket is offline
Old 02-03-2017 | 06:25 PM
Any other suggestions?
Old 02-03-2017 | 06:33 PM
SB
You running Merc recirculating pump set up or crossover ?
How cold is the water you are running in ?
Excessive Steam can be air temp/humidity......or it can be not pushing enough water thru the exhaust. Impellar/blockage/ or ?
SB is offline
Old 02-03-2017 | 06:42 PM
SB
How many hrs on engine ? Salt water use ?
SB is offline
Old 02-03-2017 | 07:51 PM
I believe it's the recirculating pump, it's in a 96 donzi 27zx. All fresh water, 300 hours. I just replaced the impeller and thermostat. If I cover the vent breather while it's running and build pressure when I release it spits a couple drops of water.
Old 02-03-2017 | 07:52 PM
I live in Orlando Florida water doesn't get too cold low 70s
Old 02-04-2017 | 12:56 PM
Ayuh,.... Sure sounds like condensation,....
The cure is to run it harder, longer,....
Bondo is offline
Old 02-04-2017 | 01:23 PM
SB
I'm hoping, for him, it's not an exhaust valve guide leaking water....just trying to cover other basis.
SB is offline
Old 02-04-2017 | 03:36 PM
might add a oil temp gauge as see where that is getting, needs to get over 200 to get rid of the moisture
ezstriper is offline
