Would you be afraid of buying a boat with these motors? >
Old 02-06-2017 | 10:35 AM
formula1's Avatar
Default Would you be afraid of buying a boat with these motors?
Hey, I was eyeing a Formula 382 with a pair of freshwater carbed HP500's with 600 "original" hours (meaning never refreshed or top ends redone) ? The motors are 1999 vintage.
formula1 is offline
Old 02-06-2017 | 10:52 AM
Buy it right with a plan to refresh. Make sure hull is dry.
ALL_IN! is offline
Old 02-06-2017 | 11:13 AM
^^^ Agreed^^^
sonicss42 is offline
Old 02-06-2017 | 11:32 AM
cigrocket's Avatar
I would get a leak down test, offer a price that covers the Top End Rebuild. The Leak down will tell you how the bottom end is. I wouldn't run the boat until I had the tops done. The HP500 has a pretty stout bottom so I bet it is fine. Tops need to be done. Buy it right and you will be happy. Plus doing the top end will give you piece of mind and you will know exactly what you have and get on a good maintenance schedule. Good luck
cigrocket is offline
Old 02-06-2017 | 10:07 PM
formula1's Avatar
Thanks for the replies so far! Any ideas on how much a top end job would cost? Also, how much would a complete rebuild cost?
formula1 is offline
Old 02-06-2017 | 10:42 PM
how does a leak down test tell the condition of the bottom end?
mike tkach is offline
Old 02-07-2017 | 01:13 AM
It would need to be priced accordingly. I would plan on spending 15k for full rebuilds sooner than later.
Top ends could probably be done for 3-4k per engine. You never know what it needs until they are apart.
Griff is offline
Old 02-07-2017 | 07:21 AM
cigrocket's Avatar
Sorry miss type, should have said The leak down will tell you how the top is. The HP 500 has a pretty stout bottom which we have seen go 750-1000HRS. Thanks Mike for pointing it out!
Old 02-07-2017 | 07:22 AM
cigrocket's Avatar
Fixed below. Thanks for the catch....lol
Old 02-07-2017 | 08:19 AM
cigrocket's Avatar
You would know at least the bottom end needed rings based on a leakdown.
