Gen 6 502 big block Rebuilt by South Florida Machine (Phil)
NO HAGGLE I WANT IT GONE PRICE $3000 FIRM
MAKE YOUR MOVE!!
Came out of a Donzi Classic 18
Call or Text 305-205-3006 Mike for pictures
Gen 6 502 big block GM Rebuilt by South Florida Machine SHOP (Phil) - Just Retired
Includes Marine Intake manifold.
Great Motor
Invoice of work done to engine is in pictures and listed below.
BELOW IS WHATS ON THE PICTURED INVOICE.
HOT TANK SERVICE
HONE CYLS. STD
SLEVE 1 CYLINDER
DECK BLOCK .010
RECONDITION 8 CONNECTING RODS
PRESS 2 PISTONS
CLEAN 6 PISTONS
MIC+ POLISH CRANKSHAFT
ALIGN HONE MAINS
VALVE JOB CYL HEADS
DISASSEMBLE AND ASSEMBLE
COMPLETE ENGINE
2- SRP2819161 PISTONS J&E
2-BPR160 CONN RODS
1- SET SRP J10051447 RING SET
1- SET CH12 CAM BEARINGS
1- 275BR BLOCK PLUG KIT BRASS
1- CS4878 GASKET SET MARINE
1- HS4886VM GASKET SET MARINE
16- HT2279 VALVE LIFTERS
1- M307 HIGH VOL OIL PUMP
1- EPR06-1201 DAMPER BOLT
8-CB743P ROD BEARINGS
1- MS829P MAIN BEARING SET
1- EPR3136 TIMING SET
1- CSC2276 CYL SLEEVE
1- ARP 435-1804 STAINLESS BOLTS
1- ARP 435-2002 STAINLESS BOLTS
1- ARP 400-7508 STAINLESS BOLTS
1- USED BBC MARINE MANIFOLD
1- DORMAN HEADBOLT KIT
MAKE YOUR MOVE!!
Great Motor
HOT TANK SERVICE
HONE CYLS. STD
SLEVE 1 CYLINDER
DECK BLOCK .010
PRESS 2 PISTONS
CLEAN 6 PISTONS
ALIGN HONE MAINS
VALVE JOB CYL HEADS
COMPLETE ENGINE
2-BPR160 CONN RODS
