new standard lower >
new standard lower
new standard lower
Old 02-10-2017 | 02:27 PM
Default new standard lower
standard b1 lower, don't need low water pick ups, not sure if i should get b1, x, xr
my upper is ow serial swept back 1.5 mr gadgets upgraded and set up for oil cooler.
whats a new lower cost?
good place to buy?
boats a pretty light 26 w/ 496 mag ho
thanks guys
outonsafari is offline
Old 02-10-2017 | 03:38 PM
Pm endeavour32 if you want. He just mentioned the other day he had a lot of various drives, uppers, lowers etc
getrdunn is offline
Old 02-10-2017 | 08:17 PM
i bought my upper from him, (it was exactly as advertised)
he has another upper i want as well but thought it might be a good idea to have 1 complete drive before i started on the spare.
i see minus 1's and 2's for sale all the time but not many standard b1 lowers and that kinda tells me something.
so whats a lower cost ? ow and later serial
Old 02-10-2017 | 10:46 PM
I'm getting ready to rebuild an XR lower with low water pick-up. It's going to get fresh gears, bearings and prop shaft seals, so it will be as good as new. If you're interested PM me.
endeavour32 is offline
Old 02-12-2017 | 05:39 PM
really want side pick ups, drives gonna be deep
Old 02-13-2017 | 12:48 AM
A regular Bravo lower will work just fine for you with the power you have.
You should easily be able to find a good used one for less than 1k.
BTW, an X lower is the same as standard Bravo.
Griff is offline
Old 02-13-2017 | 06:56 AM
thank you
