Best way to mount stand up bolster seats >
Old 02-11-2017 | 04:48 PM
Default Best way to mount stand up bolster seats
Whats the best way to mount this style of seat? I know through bolting with a flange on the back would be best, but the gas tank is their and I dont have the room or access. So should i make a stand off so im not just screwing into the 1/2" plywood floor? Or glass in some stainless to the back of the floor for screwing into? I thought of glassing in a stainless plate screwed from the back with studs sticking up too. But stainless tendency to gall over time makes me nervous too. What have you tried? What has held up? What broke or pulled out?
Attached Thumbnails Best way to mount stand up bolster seats-img_5685.jpg   Best way to mount stand up bolster seats-seat.jpg
justintocars is offline
Old 02-11-2017 | 06:13 PM
1/2" billet aluminum drilled and tapped,,been under my floor(3/4" cabinet grade plywood) for 8yrs,seats have never loosened up like in the past.
sutphen 30 is offline
Old 02-12-2017 | 04:07 PM
did you glass the plates in or just screw them to the bottom?
Old 02-13-2017 | 08:18 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
From other threads in the past:
Originally Posted by Sydwayz
Garelick Toggle Bolts are what you need Buck. They come in SS.
[ATTACH=CONFIG]525072[/ATTACH]
[ATTACH=CONFIG]525073[/ATTACH]
http://www.iboats.com/Garelick-Toggl...-view_id.38770
http://www.ebay.com/itm/Garelick-Tog...-/390386902040
I have found them at one of the home improvements stores before, but they are rare to see there.
I would not be mounting bolsters in filled holes.
Go with these toggle bolts:
http://www.amazon.com/Garelick-Marin.../dp/B0000AZ73L
or
http://www.fmwfasteners.com/products...B#.VUjLLflViko
Grainger has them too, but they are much more expensive.
Sydwayz is offline
