What models did Larry Smith build as opposed to Wellcraft? >
Old 02-11-2017 | 06:15 PM
Rhythm and Blues's Avatar
Default What models did Larry Smith build as opposed to Wellcraft?
I was looking at an Ad recently where the seller claimed that the 34' Raider was a Larry Smith. I'm vaguely familiar with these as I've looked at them before and strongly considered one years ago.
Now armed with the 1985 Wellcraft brochure it appears that it was a Wellcraft production model and not
a Larry Smith. It seems as tho he could have had his hands on the 38' Raider but I cant substantiate that. Anyone care to comment? Any resident Larry Smith aficionados here? Thanks.
Rhythm and Blues is offline
Old 02-11-2017 | 08:24 PM
Dan at Archer marine can answer this.
5050 is offline
Old 02-11-2017 | 08:26 PM
Cool, I'll just stand by. I keep up on his threads. He'll probably be here at some point..
Old 02-13-2017 | 09:52 AM
stageharbor's Avatar
Go Big or Go Home
Default Sqe
If it has an sqe hin it's Larry smith I think he also used another as well
stageharbor is offline
Old 02-13-2017 | 10:13 AM
bck's Avatar
bck
Charter Member#568
I'll give Dan a chance to answer then put my 2 cents in if he doesn't answer in a couple days.
Straight bottoms and flat decks
bck is offline
Old 02-13-2017 | 10:14 AM
bck's Avatar
bck
Charter Member#568
Originally Posted by stageharbor
if it has an sqe hin it's larry smith i think he also used another as well
tsc
bck is offline
Old 02-13-2017 | 11:18 AM
Originally Posted by bck
tsc
Thanks guys; so if I understand correctly both a TSC or SQE it could be a Larry Smith?
Maybe I should ask if anyone knows if Larry Smith built any Raiders?
Old 02-13-2017 | 01:27 PM
bck's Avatar
bck
Charter Member#568
Simplest answer is look at the hin. SQE or TSC means it came out of Larry's shops.
Asking which boats he was involved with is sort of a trick question because he designed all the hulls and some of the decks Wellcraft used for the Scarab line. I could see a seller blurring the distinction between built by and designed by pretty easily and most likely intentionally.
bck is offline
Old 02-13-2017 | 01:30 PM
Good point, appreciate that. I kinda forgot he was basically Scarab daddy...
Old 02-13-2017 | 02:08 PM
bck's Avatar
bck
Charter Member#568
Here's an LS outboard for your viewing enjoyment, but don't call it a raider
Attached Thumbnails What models did Larry Smith build as opposed to Wellcraft?-90b0e8e3-08e7-4609-9f6a-e7ce161f4eae_1.jpg
bck is offline
