Crane Hydraulic Flat Tappet Cams & More >
Old 02-14-2017 | 08:46 AM
eightsecmopar's Avatar
Default Crane Hydraulic Flat Tappet Cams & More
2 Crane BBC H-286-2 hydraulic flat tappet cams
2 sets of newer Comp Cams hydraulic lifters
15-Comp Cams guide plates
16-Manley guide plates
2- Newer double roller timing chain sets
32-rocker studs and locks
16- Intake push rods
16- Exhaust pushrods
All parts are in good condition, I switched over to hydraulic roller set up. There cams made 550 Hp on the dyno in a 532ci.
Cam #1 is stamped part # 134241 13-32-96 which I believe the 96 is when it was made.
Cam #2 is stamped part # 134242 13-06-05 which I believe the 05 is when it was made.
These cams were in my boat when I bought it so I don't know why the different dates
$400 for everything plus shipping[ATTACH=CONFIG]564780[/ATTACH][ATTACH=CONFIG]564781[/ATTACH][ATTACH=CONFIG]564782[/ATTACH]
Attached Thumbnails Crane Hydraulic Flat Tappet Cams & More-image.jpg   Crane Hydraulic Flat Tappet Cams & More-image.jpg   Crane Hydraulic Flat Tappet Cams & More-image.jpg
eightsecmopar is offline
Old 02-14-2017 | 09:32 AM
Did you make note of what lifters were on what lobes on which cam?
Baja226sport is offline
Old 02-14-2017 | 10:55 AM
kreed is offline
Old 02-14-2017 | 11:00 AM
No, I did not take the engines apart myself.....I did call Comp. Cams tech and ask if they could be reused and they told me I could but would have to go through the break in process again. I myself did not know if they could be reused or not.
