Can someone lookup serial number 0C352476? >
Old 02-16-2017 | 07:45 PM
Default Can someone lookup serial number 0C352476?
Trying to find out exactly what I purchased. Engine looks good and clean. All I can find is 83-90. Had a 350 mag flame arrestor which means nothing unless it really is.
1BIGJIM is offline
Old 02-16-2017 | 08:20 PM
TENSION's Avatar
maybe here.....
http://www.chevyhardcore.com/news/re...sting-numbers/
TENSION is offline
Old 02-16-2017 | 08:51 PM
Valve cover bolts go down center. I think the first year was 1990 for that.
1BIGJIM is offline
Old 02-16-2017 | 10:00 PM
Kefurr's Avatar
This shows it to be a 1988, not sure when the valve cover with the center bolts started but I did have an 1988 boat with a 350 and it had the valve covers with center bolts
https://www.perfprotech.com/mercury-...earch=0C352476
Kefurr is offline
Old 03-03-2017 | 11:07 AM
Here is what Mercury has listed for that serial number.
TRN: 0C352476 6010000AS MERCRUISER ALPHA
Serial/Model:
0C352476
Submit Clear Print Registration Info
Manufacture Date: 01/09/1988
Comments:
** NOT REGISTERED **
Warranty Period: None
Date Type Status Customer/Location Misc Information
01/12/1988 INVOICED ORD : 2320733-013
shawnh82 is offline
Old 03-04-2017 | 07:50 AM
Ayuh,... I believe the center bolt valve covers came out with the fuelie heads, 'n 1 piece rear main seal, in '86,...
Bondo is offline
