2 Rebuilt Velvet Drives $750.00 ea. >
Old 02-19-2017 | 12:07 PM
Default 2 Rebuilt Velvet Drives $750.00 ea.
2 Rebuilt Velvet Drive 72c Model 10-18-014. 1:1 Ratio. They were completely disassembled; the casing and all fluid tunnels were thoroughly cleaned out with solvent and blown out with pressurized air. They have new forward and reverse bronze clutch plates and new steel pressure plates. Clutch packs clearances were measured and shimmed to spec. New shaft seals, 0-rings, quad rings etc. After reassembly the output shafts were sealed up and pump pressure was tested to spec. $750.00 each plus freight. I will box up and anchor in plywood cases. Buyer pays actual freight charges. No UPS or FedEx, they weight 110lbs plus shipping containers.
https://pixhost.org/show/1436/374248..._161548683.jpg
http://pixhost.org/show/1436/3742482..._161548683.jpg
http://pixhost.org/show/1436/3742494..._150955307.jpg
http://pixhost.org/show/1436/3742497..._151434870.jpg
http://pixhost.org/show/1436/3742498..._151518237.jpg
ctuck0659 is offline
Old 02-21-2017 | 08:18 AM
Primecut: I tried to reply to your message but your box is full. If your interested, call or email me directly at 540-797-3769 [email protected]
Cass Tucker
Old 03-02-2017 | 09:20 AM
bump
Old 03-02-2017 | 09:49 AM
Just an assist
[ATTACH=CONFIG]565195[/ATTACH]
Attached Thumbnails 2 Rebuilt Velvet Drives 0.00 ea.-37424825_img_20170209_161548683.jpg
AllDodge is offline
Old 03-02-2017 | 03:34 PM
Thanks. Can't figure out how to embed the photos...
Old 03-15-2017 | 07:41 AM
Still available
Old 01-15-2018 | 12:31 PM
Are they driveline?
thedonz is offline
