Is it BAD when you pull the drain plug on your gear case.....
Jon,
Funny thing is, I was going to change the oil before I went "just to be safe", but got busy, and said, "it only has one or two runs on it, it should be fine..." Next time, I will DEFINITELY check it. At least it isn't July 4th.
Shane, I always check my lower plug about every other run just to make sure, sorry to hear about the bad news, Christmas is coming so I know what you want so be good and maybe you'll get a gear set!
I would put a preasure pump on it and pump it up..... Something sounds fishy... You could have had the oil leak out the top drive shaft gasket but I would think that water would have replaced the oil........
Jon
Jon
Put your best foot forward!
Maybe THAT is why the drive broke?
