Installing HP Transom Assemblies
Picked up some new HP transom assemblies...have a few questions:
1. Some people recommend 4200 when installing. Others install dry. What are people recommending?
2. What are the torque values on the studs inserted into the plate? What are the torque values of the nuts on the studs?
3. What are everyone's thoughts on glassing the cut out vs leaving it alone?
Thanks.
Thanks.
i just replaced a transom assembly on a omc king cobra last week.the studs just get screwed tight into the assembly,omc called for 22 lbs torque on the nuts in a circular pattern.i usually don,t use 5200 on anything that may need to be removed at some point.
I ran a light bead of 4200 just inside seal. Torque to 22-23ft lbs. kind of x pattern starting with inner 4 then outer 4. 5200 is permanent and will damage fiberglass if you need to remove again. I went with HD assys also.
yep,i have seen gel coat ripped off the boat with 5200 applied to transom assembly.
Nuts are 25 ft lbs - start with middle nuts with one pass of tightening in small lower torque moving to an X pattern for torqueing in 3 or 4 passes till 25 ft lbs is obtained on all 8 nuts. Do not tighten all at 25 ft lbs again in small X pattern passes obtaining 25 ft lbs.. Merc has the diagram of torque patterns in their service manuals..
The studs themselves are 15 ft lbs - into the bell housing
Thanks.
Thanks.
