Special Lube 101
Old 02-27-2017 | 09:15 PM
teaguecustommarine's Avatar
Offshoreonly Advertiser
Default Special Lube 101
We just received a large production run of Special Lube 101 Grease in squeeze tubes just like it used to come from Merc.
The people spoke, and we listened, and we bought a ton of grease!
Call the shop to order. Quantity discounts available! Spread the word!
(661) 295-7000
JT
teaguecustommarine is offline
Old 02-27-2017 | 09:24 PM
jeff32's Avatar
And what does this 101 grease ? Prop splines? Gimball bearing? Couplers? Anything else? All of them?
jeff32 is offline
Old 02-27-2017 | 09:26 PM
Yes its water resistant with teflon so prop splines, o-rings, water pumps, you can put it on pizza, etc.
Its good for a lot of things. At the same time it cleans up easy and doesn't stink.... Many people seem to want it.
JT
Old 02-27-2017 | 10:34 PM
I'll be calling tomorrow for some
Unlimited jd is offline
Old 02-28-2017 | 06:11 AM
Quinlan's Avatar
I just ordered replacement TBS blowers from you guys for my 575's. I might need a tube to Lube up the wife when she sees the CC bill lol
Quinlan is offline
Old 02-28-2017 | 09:17 AM
J-Bonz's Avatar
Awesome! When I run out of my tubes I stocked up on I will place an order! Great job to Bob & Team on this one! Hands down my favorite to use on everything.
J-Bonz is offline
Old 02-28-2017 | 08:35 PM
I have typically used 101 for most anything. Recently was told specifically not to use it on input shaft/coupler splines? Any truth to this.
Cory H is offline
Old 02-28-2017 | 09:16 PM
Not sure to be honest. On your typical bravo aluminum coupler we use "coupler spline grease". On steel tailstocks like a #6 we will use 101. Not necessarily a strict rule, but thats the general application.
I don't think 101 is high temp rated, but nothing greased in a boat really builds temp like wheel bearings / brakes / CV's. I would be interested in the rationale of why not.
JT
Old 02-28-2017 | 10:22 PM
How about some Teague coupon codes. 10% or some free shipping or something. Lol.
Crude Intentions is offline
Old 03-01-2017 | 06:18 PM
Tell you what, order a box of 12 and we will make it worth your while!
JT
