Twins
Old 02-28-2017 | 08:13 PM
Default Twins
How big of twins can you run in an '88 261 Four Winns Liberator that currently has twin 5.7 sb - Thank you
HacknWack76 is offline
Old 02-28-2017 | 08:32 PM
Sky's the limit. Question is, how thick is your wallet?
Cory H is offline
Old 02-28-2017 | 09:52 PM
Can't start a thread with " twins" and think we aren't looking for boobies
Drew555 is offline
Old 03-01-2017 | 04:25 AM
rak rua's Avatar
So your answer would be "bigger the better.........."
rak rua is offline
Old 03-01-2017 | 06:47 AM
Dave M's Avatar
Veteran: Navy
Did any of those boats come with big blocks? Not trying to burst your bubble but if you end game is SPEED, that hull is NOT going to yield great results.
Dave M is offline
Old 03-01-2017 | 07:27 AM
Yes they did come with big blocks. 365s if i remember correctly. 73ish mph as opposed to 57ish with 350s.
BOATMAN302 is offline
Old 03-01-2017 | 07:59 AM
Twin 400ci+ LS's should do the trick!!!
corey331 is offline
Old 03-01-2017 | 09:35 AM
That one heavy boat so as long as it is still solid I would think what every you had to spend, but at some point that boat will only go so fast.
boomer is offline
Old 03-01-2017 | 10:16 AM
I remember when century brought are old 26 Monza design to the Powerboat test with twin 365 mags.
Thing got so out of shape at any speed above 70 that they gave up on trying to clock a top speed and said Century needed to go back to the drawing board .
tommymonza is offline
Old 03-01-2017 | 10:36 AM
VoodooRob's Avatar
I would think you would want to install external steering/drives/props/engines to build a safe usable package. Plan a budget, and in the end it will be double the dollars you figured and the boat will go 1/2 as fast as you calculated. Welcome to modifying a boat.
VoodooRob is offline
