Freshly Rebuilt Mercruiser 502 Mag EFI Motor >
Old 03-03-2017 | 07:50 PM
Default Freshly Rebuilt Mercruiser 502 Mag EFI Motor
The motor originally had about 400 hours on it before the rebuild. The block is standard bore. Block has been honed, decked and line bored. New parts include Hastings OEM rings, new crankshaft and rod bearings standard size, crankshaft has been polished, connecting rods have been checked and resized, roller cam, cam bearings, oil pan gasket, timing chain cover gasket, rear main seal, oil gallery check valves, and timing chain. Cylinder heads have been milled, bead blasted, fresh valve job, seats have been radius cut, spring pressures have been adjusted to 125 #’s on the seat. Everything has been professionally machined on high quality equipment. The motor includes and is complete from oil pan to valve covers and from balancer to flywheel. Starter and water pump are included. The motor is perfect for someone who wants to upgrade from a 454 to a 502, who has a tired motor or who needs a motor to replace their failed unit. Its ready to go and can be picked up or shipped at purchaser’s expense. Buyer can arrange shipping. I have someone who can crate the engine for additional cost (approximately $175). Create loading with a forklift from shipping location. The motor is located in Rochester, NY at the Machine shop where the work was done. $5500 OBO[ATTACH=CONFIG]565231[/ATTACH][ATTACH=CONFIG]565232[/ATTACH][ATTACH=CONFIG]565233[/ATTACH][ATTACH=CONFIG]565233[/ATTACH][ATTACH=CONFIG]565233[/ATTACH][ATTACH=CONFIG]565233[/ATTACH][ATTACH=CONFIG]565234[/ATTACH][ATTACH=CONFIG]565235[/ATTACH][ATTACH=CONFIG]565236[/ATTACH][ATTACH=CONFIG]565237[/ATTACH][ATTACH=CONFIG]565238[/ATTACH][ATTACH=CONFIG]565239[/ATTACH][ATTACH=CONFIG]565240[/ATTACH]
Attached Thumbnails Freshly Rebuilt Mercruiser 502 Mag EFI Motor-img_5893.jpg   Freshly Rebuilt Mercruiser 502 Mag EFI Motor-img_5894.jpg   Freshly Rebuilt Mercruiser 502 Mag EFI Motor-img_5895.jpg
Freshly Rebuilt Mercruiser 502 Mag EFI Motor-img_5896.jpg   Freshly Rebuilt Mercruiser 502 Mag EFI Motor-img_5897.jpg   Freshly Rebuilt Mercruiser 502 Mag EFI Motor-img_5898.jpg
Freshly Rebuilt Mercruiser 502 Mag EFI Motor-img_5899.jpg   Freshly Rebuilt Mercruiser 502 Mag EFI Motor-img_5904.jpg   Freshly Rebuilt Mercruiser 502 Mag EFI Motor-img_5905.jpg
rwysowski1 is offline
Old 04-15-2017 | 08:09 AM
Bump
Old 05-26-2017 | 07:42 PM
Bump
Old 06-26-2017 | 12:11 PM
Bump
