Where can I buys these >
Old 03-04-2017 | 03:15 PM
F-2 Speedy's Avatar
Default Where can I buys these
Thunderbolt thingy...
F-2 Speedy is offline
Old 03-04-2017 | 03:19 PM
c_deezy's Avatar
http://www.mercstuff.com/sensor.htm
or
http://bpi.ebasicpower.com/shop/inde...90e8665f0b6f1c
I think I have one new in box from a boat we no longer have. I'll check and if you are interested let me know.
EDIT: I just checked, I do have one new in box. 892150q02, New in box, $40 out the door if you want it.
c_deezy is offline
Old 03-04-2017 | 03:51 PM
F-2 Speedy's Avatar
Thanks, Ive seen those before but thought they weren't correct, they've changed them from the original, the timing module also wires to those studs on the one I posted
Old 03-04-2017 | 04:04 PM
[QUOTE=F
Might try taking it to a GM - Chevy dealer. When I had on go bad years ago I got one from a Merc dealer for a lot of $. Had a friend on the dock at the time that retired from GM and was involved in a lot of their R&D including to coil per cylinder set up. He said it was just a standard GM part and more than likely just needed to have the solder joints re done. I think after him telling me that I researched and found the GM part number etc.
Way cheaper than from Merc dealer.
GETTINBYE is offline
Old 03-04-2017 | 04:34 PM
i think it is a merc only item,never seen that in a gm dist but i could be wrong.
mike tkach is offline
Old 03-04-2017 | 06:53 PM
That is a merc only item. West marine sells a Sierra replacement for about $65. The one with studs is obsolete, the new part number has short leads and bullet connectors
Unlimited jd is offline
Old 03-04-2017 | 07:11 PM
F-2 Speedy's Avatar
I found one NOS module
Old 03-04-2017 | 10:12 PM
u have v6-14 module
I'CE is offline
Old 03-05-2017 | 06:28 AM
bck's Avatar
bck
Charter Member#568
Is this the part that people say is Chinese junk now?
Straight bottoms and flat decks
bck is offline
Old 03-05-2017 | 07:35 AM
SB
Yup !
This summer dealt with a broken t-bolt pick up due to a new rotor that was tweaked and I didn't notice....was not about to put in a newer pick-up that many complain about reliability problems. Searched people that I knew that had replaced their Tbolt distributors with something else. like MSD or etc, and asked if they wanted to sell their old pick-up.
I have a bunch of boats I work on that are from late 8o's and 90's that have a quazilion hrs on their OE Tbolt pickups...
Edit in: the pick up shown by Speedy above is the old style good one's. The newer one's have leads you need to crimp. Gone are the posts w/nuts.
SB is online now
