#3 Outdrive Extremely hard to find !! >
Old 03-06-2017 | 09:56 AM
Default #3 Outdrive Extremely hard to find !!
I have a Extremely hard to find #3 Outdrive it is a right hand SSM III 1.68:1 overall gear ratio. Upper driveshaft housing has 1.5:1 near net drop forged gears. "The Good Ones" The housing assy is basically new and only has the 3 hours on it. Lower gearcase assy is a R.H, 1.125:1, resealed and reshimmed, propshaft is speedi-sleeved, I bought another set so I'm selling this one. I also have another set that needs repair. I also have the housing for both sides and hydraulic trim cylinders .
You can pm me or email at [email protected] 903-352-5500
J.Clint Kellam is offline
Old 03-06-2017 | 07:36 PM
phughes69's Avatar
Extremely rare??????
phughes69 is offline
Old 03-06-2017 | 08:48 PM
This gear ratio is hard to find..!!!
Old 03-06-2017 | 08:49 PM
If you say so.
Unlimited jd is offline
Old 03-06-2017 | 10:34 PM
phughes69's Avatar
They are????
1.5 ratio drives http://www.offshoreonly.com/forums/s...lt-1-50-a.html
1.5 ratio drives http://www.offshoreonly.com/forums/s...s-gimbals.html
1.5 ratio drives http://www.offshoreonly.com/forums/s...24-8500-a.html
1.5 ratio upper http://www.offshoreonly.com/forums/s...3-3-upper.html
1.5 ratio drives http://www.offshoreonly.com/forums/s...eft-right.html
1.5 ratio drives http://www.offshoreonly.com/forums/s...gs-marine.html
Old 03-06-2017 | 10:35 PM
1.68 overall
Old 03-06-2017 | 10:39 PM
Guess you didn't look at the photo add, if you have any further questions or comments your welcome to call me!
