Merc 900 valve Springs and lifters >
Old 03-11-2017 | 01:01 PM
Default Merc 900 valve Springs and lifters
Anyone know who made the springs and lifters for 900's ? Want to source everything before we pull it apart.
Unlimited jd is offline
Old 03-11-2017 | 01:35 PM
call me before you buy Jamie... I might be able to help you
adk61 is offline
Old 03-11-2017 | 04:10 PM
Is that the crane solid roller 252/257-672/672
getrdunn is offline
Old 03-11-2017 | 04:28 PM
Sounds about right
Old 03-11-2017 | 06:02 PM
I use comp cams springs for replacement. For seasons and no problems. I put new Springs in every spring
JJ30 is offline
Old 03-11-2017 | 08:28 PM
Happen to have a part number ?
Old 03-11-2017 | 08:38 PM
Which comp springs? I only did a quick search but couldn't find any comps similar to the recommended crane spring #99876.
160 closed @ 1.968
468 open @ 1.348
Seems pretty light pressures for that cam but it's what the card shows.
getrdunn is offline
Old 03-11-2017 | 08:50 PM
That's way light for a 6200 rpm solid roller sc engine imop
Where did you find that? Per the camshaft recommendation?
Old 03-11-2017 | 08:56 PM
Right off the cam card. I hear ya. I've used way more spring on hyd roller cams with solid lifters.
getrdunn is offline
Old 03-11-2017 | 08:58 PM
Makes no sense I know but pm me your ph number and I will tx you cam card.
getrdunn is offline
