Oil Line Fittings
Old 03-12-2017 | 08:35 AM
Default Oil Line Fittings
After installing my engine I have decided to replace all the oil line as they are old and I cannot figure out how they had the whole setup in the boat anyways. It has OMC stuff on if that makes any difference. I was looking online and can't seem to find these exact fittings. They look like a hydraulic fitting to me with an o-ring and the line is 5/8.
Tahoe540 is offline
Old 03-12-2017 | 09:06 AM
they look the same as PS fittings, if I were you I would change everything out to reg pipe thread and an fittings, going to be tuff finding that stuff now, even special hose places dont carry much of that...
ezstriper is offline
Old 03-12-2017 | 09:13 AM
OMC does make a difference. What motor and I'll guess its a 1990 version as seen in your sig?
Changing everything would be easiest, but cost the most , maybe
AllDodge is offline
Old 03-12-2017 | 09:26 AM
Thanks guys, this is what I was thinking I was going to have to do. I was trying to find fittings to adapt to AN fittings so I can just run AN hose but was not thinking this would be my luck.
Yes this is a 1990 and unfortunately they put stock OMC oil cooler crap and an OMC electrical harness in a custom boat. I bought the boat as a project and trying to figure out the wiring is a total joke too as there are some hookups that are not used (knock sensor and other sensor hookups) and of course does not install in a location it was meant for. My buddy is a mechanic and great with electrical and said he wants to just make a completely new harness. Anyone ever do that? Not much to them from what we looked at.
Tahoe540 is offline
Old 03-12-2017 | 09:35 AM
It takes some buying and returning to find just the right one.
Keith Atlanta is offline
Old 03-12-2017 | 09:49 AM
Custom is easy and doesn't take that much to accomplish, builders use them quite often
http://www.cpperformance.com/product...ng-harness.htm
AllDodge is offline
Old 03-12-2017 | 08:47 PM
When ever I get a project boat, 1st thing I do if any of the wiring is questionable, rip it all out and build a new wiring harness from scratch. That way you know what you have. If you should have a problem down the line at least you know about the wiring. I have done all of my own engine harnesses for years. Never had any problems. I have redesigned many dashes and built the harness from dash to motor. If you take your time and do it right, you will never regret the time it took to do. It's the best insurance you can have. Piece of mind that you did it right.
gofastboater is offline
Old 03-13-2017 | 04:04 PM
I was looking at oil coolers to replace and I saw this one had both coolers in one. Would this be large enough for my setup? Also, this will be a Tahoe boat that will have pretty cold raw water cooling it.
http://www.cpperformance.com/p-13484...on-cooler.aspx
This also looks interesting as you have no plumbing. Anyone have any experience with these?
http://www.cpperformance.com/p-14266...34-length.aspx
Tahoe540 is offline
Old 03-13-2017 | 04:37 PM
F-2 Speedy's Avatar
The thing is with those 6 foot cannon plug you still need to use part of the other harness,or at least I did. I just wired my two engines with the ebasics one, the factory Merc. harness has all the grounds and power leads bonded together inside the wrapping. I found it easier to reuse the large power and ground wires going to the alternator and starter and bring all the grounds to a terminal block and all the power off the Aux side of a 50amp breaker.
F-2 Speedy is offline
Old 03-13-2017 | 04:41 PM
With your motor being stock, the combo cooler should work fine. Looks to be the same as used on older Merc 454
http://www.mercruiserparts.com/bam/s...31802/1621/300
Have not used the other item
AllDodge is offline
