Parts: Exhaust Tips, Bellhousing, Transom Assembly, Trim Cylinders, etc.
A buddy and I have decided to finally compile some parts to get rid of stuff we no longer need. Random parts that have been piling up. Someone out there can make use of this stuff. All items are as shown and as-is. Part numbers may not be completely accurate. All prices are OBO. Will be updating this original post with more parts.
Gimbal Housing/Gimbal Ring
8M0096216 and 8M0062440
$450
Bellhousing
41646-C7
$300
Trim Cylinders
98718 and 98719
$200
Exhaust Tips (brand new, never been installed)
4" Diameter
10" Long
Stainless Steel
With Flappers
$200
Header Clamp
54-8M0051201
$20
Upper Swivel Shaft
98230A1
$150
Rule Bilge Pump
$8
Flo Torque Hub Assembly
850821-1
$30
Sea Dog Gas Lift Mounts (NEW)
321581-1
Quantity (4)
$4 Each
Dana Step Plates
SP-734
$30 (for pair)
Heavy Duty Mount Kit for Hatch Lift Eddie Marine - (NEW)
302-05
$100 (retail = $153)
Water Circulation Pump **** Needs Rebuild
811573A04
$80
Engine Shipping Crate Mount
$30
Steering Actuator Hydraulic End Piece
$10
Inner Transom Plate
44116
$100
Battery Charger
$15
Boat Cover Tie Downs (NEW)
$30
$450
Bellhousing
41646-C7
$300
Trim Cylinders
98718 and 98719
$200
4" Diameter
10" Long
Stainless Steel
With Flappers
$200
Header Clamp
54-8M0051201
$20
Upper Swivel Shaft
98230A1
$150
Rule Bilge Pump
$8
850821-1
$30
321581-1
Quantity (4)
$4 Each
Dana Step Plates
SP-734
$30 (for pair)
302-05
811573A04
$80
$30
$10
Inner Transom Plate
44116
$100
Battery Charger
$15
$30
Received payment, thank you. Shipping FedEx tomorrow.
BUP, clear your PM's so I can get you the shipping details. Thanks.
