BoatUS Releases New Must-Watch Boat Onboard Fire Video >
Old 03-23-2017 | 10:47 AM
Correspondent
Correspondent
Default BoatUS Releases New Must-Watch Boat Onboard Fire Video
The latest onboard fire video from BoatUS is essential viewing for powerboat owners, https://speedonthewater.com/in-the-n...ard-fire-video.
Matt Trulio is offline
Old 03-23-2017 | 11:37 AM
WARPARTY36's Avatar
Drive to arrive alive!!!
I've been around a couple of boat fires, and it happens fast. The first one was sad to see burn to the water. The second one, I made the dumba$$ mistake of extinguishing the fire. We should've let it burn
WARPARTY36 is offline
Old 03-23-2017 | 11:58 AM
Correspondent
Correspondent
When I was a teenager, I saw a boat burn to the waterline. I'll never forget it. "Fast" doesn't even begin to describe it, right?
Old 03-23-2017 | 01:02 PM
that's great to know that the typical hand held extinguisher we're all required to keep on board was found to be "basically useless"
blckkat is offline
Old 03-23-2017 | 03:17 PM
Too Stroked's Avatar
An onboard fire extinguisher isn't totally useless. You just have to be prepared to use it in a real hurry - and correctly - if you want it to have any effect at all. Once the fire gets rolling though, don't waste your time or risk your life.
Too Stroked is offline
Old 03-23-2017 | 03:20 PM
I watched the mti in Havasu last year at desert storm burn to waterline. We we about the first on scene and watched as they jumped off boat . Scary how fast it went up. They tried as well but nothing was stopping it.
jeff s is offline
Old 03-24-2017 | 10:25 AM
Correspondent
Correspondent
Fiberglass and resin burn ferociously. And you definitely wouldn't want to inhale any of the smoke from that kind of fire.
Old 03-24-2017 | 08:55 PM
aquaforce's Avatar
Wow, happens fast.
Hopefully the fire extinguisher provides a means of escape if needed. That is about all to count on it for is what I've been told in classes.
aquaforce is offline
