Using IMCO standoffs on a Hustler 388
I posted this in a different thread, but after reading the title I think it is a separate thread... Hopefully someone here will chime in. I'm in the process of repowering a '99 388 poker run and considering installing 12" imco boxes I have access to. Right now I have HP500s and bravo outdrives. My questions are, if I use the standoffs and the bravo drives what should I expect? I know there are better options, but I'm trying to make use of the outdrives I have for now with the thought I could upgrade in the future. Also any idea on prop pitch for this setup? Any guidance or personal history would be greatly appreciated.
Thats what I figured. Thank you for the reply . I thought about picking up a pair of short lowers when I found a decent deal. Any disadvantage to running standard lowers until then? Anybody have experience with the standoffs?
From info I gathered, our 388's actually like the drives a bit deeper. More leverage. I planned to either do boxes or spacers. Obviously spacers were much cheaper and done in a few hrs so I added them. Haven't had test time yet but from how the boat originally blew out 4 blades bad, and needed 5 blades, I think I'm making a smart move.
The boxes will give you more trim leverage. With boxes and the drives at the correct height you won't need as much trim. I use very little trim now after installing the boxes and getting the props at the correct height.
Well I decided to try the boxes. I'll keep you updated on how it goes. I wont have a true before and after because the motors that are going in the boat are not the ones it ran before, but I am excited to get it together!
I think the poker run would like the -2's... less bow weight needed to leaverage. But, hey, this is why we test right?!? Appecitate you sharing your info. I will be testing 4 and 5 blades with my -0 IMCO with spacer as well.
