WTB P/S bracket and rec  W/P pulley HP500 >
Old 03-28-2017 | 02:54 PM
Default WTB P/S bracket and rec W/P pulley HP500
I have the last generation 99 HP 500 with an added cross over set up and want to return to stock, I need the water recalculation pump pulley (can be black doesn't need to be blue) this is the v belt set up. I also need the Power steering pump bracket for the factory location as it had a Procharger at one point and the pump is currently mounted on the starboard side, again just trying to put it back stock.
Thanks,
Michael
Donzi1979 is offline
Old 03-28-2017 | 04:53 PM
Sick Stinger's Avatar
Brotherhood #1
I have a PS bracket I may have the pulley also but need to check.
Sick Stinger is offline
Old 03-28-2017 | 04:55 PM
Sounds good
Old 03-28-2017 | 06:38 PM
Brotherhood #1
Yup have them both for you.
Old 03-28-2017 | 09:35 PM
Perfect sent you a PM
