271 Fastec
Old 04-04-2017 | 07:46 AM
Default 271 Fastec
Anyone having any idea on "roughly"how fast a 271 Fastec Hull would go with 700 HP
1.50 Ratio
250lb driver
200lbs fuel
Prop ?
Papasmurf is offline
Old 04-04-2017 | 08:07 AM
I would say low 70's
boomer is offline
Old 04-04-2017 | 12:47 PM
Post #98 should refresh your memory.
http://www.offshoreonly.com/forums/f...ech-mph-4.html
4mulafastech is offline
Old 04-04-2017 | 12:51 PM
Let me add more to the story.............
My 252 Formula Bowrider went from mid 50s with 330HP to mid 70s with the 720HP motor in it currently
The 252 has a standard V Hull and weighs 4525lbs according to Formulas spec sheet.
The 271 in question, currently runs mid 60s with stock 502Mag with 415HP Fastec Hull design, but weighs 725lbs more than my 252.
I would assume low 80s but was hoping someone on here had a 271 Fastec with similar power
Old 04-04-2017 | 12:59 PM
I had a 2000/271 with 635 HP, 1.50 XR 26P bravo 1 80-81 depending on conditions.
Rattlesnake Jake is offline
Old 04-04-2017 | 01:00 PM
4mulafastech.........you so good, thanks!
Long time no talk to.........all good in your world?
Old 04-04-2017 | 06:19 PM
My 242 with 572hp runs 74. I would say mid 80s for the 271 with more power.
79formula is offline
Old 04-05-2017 | 12:39 PM
All is good! Looking forward to another great boating season in the 292.
Old 04-06-2017 | 09:13 AM
I know exactly how fast it will go. you have basically the same motor as mine built by the same person. The problem is the hull and the chine walk problems. No problem running low 80s with a box stock 28 pitch bravo prop with at least quarter throttle left . After 80 the chine walk gets scary. Have not dialed in a prop , never tested a set up with an extension box or shorty drive. Have looked in to having the bottom blueprinted but not cost effective for a formula. So to answer your post. Low 80s with safety in mind. All these speeds are on a livorsi gps speedo with 100 gallons of fuel and 3-4 people on board. I'm not one of those people that give speeds with 5 gallons in the tank and one person aboard holding their tongue the right way and a 20 mph tail wind. You can take these numbers to the bank. Just come to Greensboro and look at my boat if you want one . Jeff wurl
jwurl is offline
Old 04-06-2017 | 09:19 AM
I see you have a boat in mind. Don't forget you need full hydraulic steering . Real merc 280 tabs with indicators and at least an xr drive and hp gimbal . . The stock 271 tabs are worthless . Would not even consider tying these speeds in a 271 without the other upgrades . . Jeff wurl
jwurl is offline
