Top Gun Swimplatform
Old 04-04-2017 | 08:21 PM
Default Top Gun Swimplatform
I am interested in re finishing our aluminum swim platform. Plan on blasting it first for prep. There is some corrosion and pitting. Any advise as to what I can use for filling? Also how should we finish it. Will powder coat work on a filler? Or am I stuck with paint? Thanks.
1MOSES1 is offline
Old 04-05-2017 | 01:52 AM
It depends on how deep the pitting is. Powdercoat will fill in and level out small imperfections.
Griff is offline
Old 04-05-2017 | 08:03 AM
Too pitted to cover with powder coat...
1MOSES1 is offline
Old 04-05-2017 | 08:28 AM
Then use body filler to smoothe out the imperfections...and paint it.
kreed is offline
Old 04-06-2017 | 01:30 AM
glassdave's Avatar
Neno the mind boggler
you also have to be careful when powdercoating pitted or corroded aluminum. the heat/baking part of the process can cause out gassing in oxidized areas.
08 OPA High Points Champion
glassdave is offline
Old 04-25-2017 | 07:51 PM
Zero Patience's Avatar
Blast, then Alodine conversion process, acid then converter, then filler, then awlgripTwo part epoxy primer, then sand, then primer again if you sanded through, then awlgrip
Zero Patience is offline
