Power One applicators
Just wondering what everyone is using to apply Power One hull cleaner with? I try cutting 50/50 with water and using it in a spray bottle but it seems that the seals are rotted after a couple of days. Do you just pour it on a sponge and apply or what?
i have a friend in the spray bottle manufacturing biz and pretty much go through a bottle every time i use the stuff lol. I wonder of one of those cheap weed/deck sprayers would work since its not actually going through a pump but rather a simple valve.
08 OPA High Points Champion
I use a Rural King spray bottle - and have for about 3 years since I started using PowerOne. I also cut it down, but about 3-4:1 - although I don't measure. Then I use a soft brush to work it in and then spray off.
I have been using a 2 gallon garden sprayer for years. I use it straight out of the bottle,no mixing with water. Spray it on and hose it off. When done clean the sprayer with fresh water and run some water through the sprayer.
I use a cheap $10 1 gallon pump garden sprayer to spray on muratic acid. They usually last about 3 years.
I've done used acid toilet bowl cleaner in a regular spray bottle and after sitting for week its done.
