closed cooling system kit 750hp >
Old 04-09-2017 | 07:37 PM
Rhythm and Blues's Avatar
Default closed cooling system kit 750hp
Evening, who is producing a closed cooling system kit for 750hp ish power? I see a lot of 500hp and some 650hp but havent seen much in the way of 700-800hp stuff. Does anyone have a leed for a reputable system? Thanks.
Rhythm and Blues is offline
Old 04-10-2017 | 07:34 AM
you just need a large heat exchanger, there is a company in NY Mr Cool I think that sells oversize ones(I bought 2 years ago and still using them ) and you will have to make up the rest, not a big deal, you will have to run a circulating pump if running a crossover now. Its not bad after you mount the exchanger
ezstriper is offline
Old 04-10-2017 | 07:48 AM
Ok, yeah I think yesterday I followed some thread links to Mr. Cool website. Thanks
Old 04-10-2017 | 08:06 AM
http://www.sen-dure.com/
Whipple recommends this company when the stock Merc setup is not enough.
Ryan00TJ is offline
Old 04-10-2017 | 08:10 AM
Ayuh,.... Unless ya got a Brand New motor, don't even think about addin' closed coolin' to a used motor, especially if used in the brine,...
Bondo is offline
Old 04-10-2017 | 09:01 AM
Hhmm... 50hrs?
Old 04-10-2017 | 02:18 PM
DiamondPerformance's Avatar
Offshoreonly Advertiser
http://www.diamondperformanceparts.c...cat=297&page=1
www.diamondperformanceparts.com
[email protected]
http://www.facebook.com/pages/Diamon...07878772615803
302-521-0123
The Best Parts & Service At The Best Price
DiamondPerformance is offline
Old 04-10-2017 | 02:45 PM
Originally Posted by DiamondPerformance
Thanks, I think I roamed onto your site last night. PM sent.
Old 04-10-2017 | 08:19 PM
You could try Savage Manufacturing in NZ. The boat I have came with Savage oil coolers so when it came time for engine coolers I chose to keep everything the same the fella down there seemed to ask all the right questions hp level, ambient ocean temp, how we wanted the inlet and outlets arranged etc you can get horizontal or vertical units depending on your space they are all custom built to suit your engines cooling requirement.
Stainless Steel,chrome played very happy with my set up.
kriegtea is offline
Old 04-10-2017 | 08:49 PM
Hugh, that sounds interesting. New Zealand? Someone asking all the right questions is key for someone not that familiar with how to set up the heat exchangers. Thank you.
