What can make 500 EFI shoot oil out the dipstick tube?
Refreshed both motors over the winter - top ends done on both motors.
Mobil 15-50w oil
Mobil 1 oil filters
Port engine oil pressure gauge reading 60psi at idle, starboard reading 40psi at idle. Launched boat and ran at 3300-3500 rpm for about 5-10 mins. Powered up to 4500 - 4700 rpm and then smelled oil. Gauge on port motor was pegged at 80psi! Other motor normal at 50psi. Stopped, open hatch, saw about 4 ounces of oil had spewed out of diptick tube all over front of engine.
The only thing I can think of right now is changing the oil filter bypass valve in the block (GM 25161284) I ruined the old one taking it out.
Anybody have any thoughts?
Mobil 15-50w oil
Mobil 1 oil filters
Just to make sure on the same page, last fall you indicated you only had 80hrs on the motors. Why the rebuilds again ? IE: What happened ?
For those who didn't see or remember this (like me) here is a thread he posted last fall with driveability issues and what performance parts are in these motors:
http://www.offshoreonly.com/forums/g...0efi-help.html
