Replacement for pop up cleats and door jam. >
Old 04-14-2017 | 09:46 AM
Default Replacement for pop up cleats and door jam.
Does anyone know what type of spring loaded pop up cleats were used in my 2008 35' Fountain Lightning? A couple are bent and no longer pop out. They've been straightened and lubricated a few times but I need something new. I'd just as soon get a pull up cleat that would fit, if anybody knows what would work with the existing holes.
While I'm at it, my cabin door lock actually ripped out of the door, so a screw no longer holds. Epoxy doesn't hold the latch on the door very well and breaks loose while running. It would make sense to hold the door open while running so it doesn't repetitively slam. What's the best way to do that and if possible tell me which fitting to purchase.
Thanks-
drfred is offline
Old 04-14-2017 | 10:02 AM
This is probably it.
http://greatlakesskipper.com/southco...t-pop-up-cleat
These are on my boat.
HyFive578 is offline
Old 04-14-2017 | 10:45 AM
Looks like an exact match, thanks!
drfred is offline
Old 04-17-2017 | 06:32 AM
dcb
My 07 uses Accon slimline 8" cleats.
dcb is offline
Old 04-17-2017 | 09:51 AM
They look like better cleats but cost more. 165$ vs 90$. But if you're rafted up and get hit with a boat wake, mine bend and no longer pop back up. They also are a slightly different size and shape.
drfred is offline
Old 04-17-2017 | 10:08 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Thanks-
There is a little flip catch that screws into the floor, and flips over the track of your door. It holds it open for running. I did a quick search, but can't find it.
Sydwayz is offline
Old 04-17-2017 | 10:38 AM
I have had Accon on both Velocitys, great products and strong.
Padraig
Padraig is offline
Old 04-17-2017 | 12:50 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Found a picture of one, used in a different fashion. But you get the idea. You screw this into the floor, right at the point where having it flipped over your door track, will keep your door pinned into the open position.
Here it is; Perko part:
http://www.perko.com/catalog/cabinet..._&_door_stops/
http://www.ebay.com/itm/WINDOW-SLIDI...JXUGyZ&vxp=mtr
Sydwayz is offline
Old 04-24-2017 | 08:48 AM
That is what they use on my Formula 292, works GREAT
boz251 is offline
Old 04-24-2017 | 09:27 AM
Thanks. Ordering it now!
drfred is offline
