Hooking up 525 Smartcraft to Simrad NSS >
Old 04-16-2017 | 04:55 PM
Default Hooking up 525 Smartcraft to Simrad NSS
Just as the title says, I am looking to hook up a pair of Merc 525s to a Simrad NSS unit. If twin engines, I would assume use Vessel View Link as the gateway, part #8M0110641. What else will be needed to hook this up correctly. Junction Blocks, Terminating resistors, wiring harnesses etc... part numbers would much appreciated.
Thanks in advance.
DocktorsOarders is offline
Old 04-17-2017 | 10:28 AM
I'm in the process of considering something similar (but with Garmin). I believe all you need is the gateway.
https://embed.widencdn.net/pdf/plus/...R.pdf?u=orhjei
ALL_IN! is offline
Old 04-17-2017 | 10:35 AM
Here's a quick schematic from when I installed a Vessel View 7 (NSS 7) in my boat last year.
I used to have a list of all the cable part numbers and such, but I can't seem to find it right now.
EDIT:
Found a couple more bits of info...wish I'd kept better track of this at the time, for future use. lol Hope this helps.
Wasted Income is offline
Old 04-17-2017 | 11:53 AM
In order to get the information on the GPS whether it is a Simrad or Garmin you will need the mercury gateway yes and also set up a NMEA2000 backbone to hook up the mercury gateway to the units.
The NMEA2000 backbone needs to have power also.
Double Rigged is offline
Old 04-17-2017 | 12:36 PM
Right - I failed to make that point. I put in a powered backbone when I installed my Fusion headunit and remote.
Wasted - is the Link cable already present in stock form, or do you have to add that?
ALL_IN! is offline
Old 04-17-2017 | 01:27 PM
I started with zero smartcraft wiring to the helm, so I had to start from scratch basically. If your boat already has any sort of smartcraft gauges or monitors, or if the smartcraft cables are already run to the helm, it gets a lot easier for you.
The older VesselView 7 has the smartcraft gateway built in, so I didn't need to deal with any of that. However, i'm currently upgrading to a Vessel View 702 (NSS Evo2) and that unit uses the same 8M0110641 smartcraft gateway.
You will still need all the items between the 6 port junction box and the engines.
Old 04-30-2017 | 02:49 PM
Barrydet's Avatar
This question is directed to "wasted income" . Have you completed your upgrade to the 702? If so, are you getting a "rudder position/steering indicator" on your display screen? I completed an upgrade from the first generation "system view" to the VV502. It is the smaller display version of what you are using. I am not getting a "rudder position/steering indicator" display. The retail vendor and Mercruiser customer service have been of zero assistance. I posted a thread titled Vesselview 502 a while back. Thanks
Barrydet is offline
Old 05-01-2017 | 06:14 AM
Dave M's Avatar
Veteran: Navy
You are going to need Merc part #8m0105243. That is the CAN -> NMEA 2K gateway. If you already have a nmea 2K backbone and an open j-box port, that's all you need.
Dave M is offline
Old 05-01-2017 | 07:43 AM
VoodooRob's Avatar
Holy crap lots of info backbones, links, etc, I want to get rid of the Smartcraft and install a newer unit. Hopefully I can get with one of you techies before I get started.
VoodooRob is offline
Old 05-01-2017 | 12:07 PM
You are saying that you desire to have the rudder/steering indicator on the screen, but it's not showing up?
I finished my install, but the boat hasn't been wet yet. I personally don't have or need the steering/rudder stuff, since to my knowledge, the 496/bravo package in my boat doesn't have those sensors.
