Small block cooling
I'm trying to decide if I spend the money on a closed cooling system or keep open. I have a Domzi Classic 18 and want to be able to run up to an hour at 5000-6000 rpm on a SBC (special build). Is the most efficient/effective cooling for oil etc best with an open system? Thank you
I've got a built 383 stroker with a closed loop system, manifolds also closed loop. In the 100+ degree heat and 80+ degree water temps it runs hotter than I'd like. I only do fresh water so I've actually thought about removing the system and going open system. Hope that helps.
Ultimately, I landed where you did which is an open cooling system. I did make some rough calculations and could not see any benefit to not leveraging the massive capacitance of an inland lake.
Regarding the Donzi, I will attach a link. My bad. The boat started out yellow... repaired the hull, applied new gel coat and striping, replace stringers and transom, built a splayed 388 engine and replaced Volvo outdrive with a MerCruiser bravo outdrive
The restomod is now complete and have had several thermal runs where I was able to maintain 65 mph on Lake Huron for almost an hour. I think that’s good enough for what I was I was after.
http://s750.photobucket.com/user/dav...=recent&page=1
