Bravo 3 propellers choice. Best guess needed.
Single engine 450hp 3600 lbs deep v 21' bow rider
Switching from 1.5 ratio bravo 1 with 21p to bravo 3 with 2.0 ratio.
I want strong holeshot.
I just bought the b3 and it did not come with any propellers.
What would be a good set of props to get a baseline?
26 or 28...sounds like you were already a little on the low number end with the 21p and 450hp. You will have a great holeshot either way. Make sure the B3 trim limiters are utilized. I just swapped an old B3 on my boat last summer out of curiosity and I doubt that I'll ever put the B1 back on. Then again, I'm only running a stock 502 Mag (415HP) so I lost really nothing top. On most 65mph-ish boats, its going to be all positives. The only small negative that I have is a little looser handling a higher speeds...the B3 will lift the stern more than almost any single prop.
Call Brett at Bblades and tell him what you have and he will tell you where to start and you can also use his test prop service to make sure you get the right set before purchasing. What is the engine's max RPM?
