Through hull pickups >
Old 04-20-2017 | 09:09 PM
Default Through hull pickups
Motors are currently out of my cat, and I am trimming my through hull water pickups that are currently 1 5/8" below the bottom. Do I cut them flush with the bottom and then cut a water groove in front of them if needed. Or have the leading edge flush with the bottom and leave the back 1/4 inch to 1/2 inch below??? Need an answer soon
rob vanharten is offline
Old 04-20-2017 | 09:20 PM
Rob, Hope this helps.
http://www.offshoreonly.com/forums/g...pped-hull.html
getrdunn is offline
Old 04-21-2017 | 01:01 AM
My Pantera and AT had/have through hull pick ups. Both flush at the hull and less than 1/4" lower at the trailing edge.
Griff is offline
Old 04-21-2017 | 08:23 AM
Thanks guys!!!
Old 04-22-2017 | 06:11 AM
Since it is already through your hull/bottom, I would trim what you have to avoid glass work. Pickups on my DCB go through the bottom also, mine has a groove that leads to the pickup, water pressure at 125mph cracked the glass and did some damage where it was ground thin. If it was mine I would just angle the pickup starting with a 1/4" at the rear, flush in front and forget grinding a groove. Even better, grind the front half flush and angle it back half way. If your pressure is too high just whittle away at them.
I am surprised that thing didn't porpoise like mad, my prediction is you will pick up 4 or 5mph. I cant imagine the amount of drag on those, look at what labbing props does...
JRider is offline
Old 04-22-2017 | 03:34 PM
The pickups were not sealed with anything. They just have a gasket and we're through bolted. I was able to completely remove them and cut them out of the boat. They will be flush at the leading edge and angle cut to be 1/4" deep at the trailing edge. When I reinstall do you think I should use some 5200 to make sure water doesn't make it into the coring? I am hoping for a 5mph hour gain with just the pick up fix. However adding another 100hp a side so it will be hard to tell for sure...
Old 04-22-2017 | 06:48 PM
Good plan and you can always add the water channel groove if needed!
4200 is plenty plenty strong, I would not use 5200. We picked our boat off the trailer when trying to remove the extension boxes with 4200, can't imagine 5200!
offshorexcursion is offline
Old 04-22-2017 | 08:05 PM
its even worse,,I needed alot of heat on the boxes plate to soften it enough.totally sucked,almost hurt the gel coat but did get lucky.
sutphen 30 is offline
Old 04-22-2017 | 09:37 PM
When I parted out my formula with number V's I had installed the boxes with 5200. When we tried to removed them it took a 10,000lb 4wd diesel high low doing neutral drops to rip them off. When they finally gave it took gel coat and plywood with it. Crazy stuff!!!
Old 04-23-2017 | 02:26 AM
4200 has half the adhesive strength and all the sealing of 5200.
Griff is offline
