Good compression vs Bad compression
this is what Merc recommends and still currently below in their service bulletin. They list in all the current service manuals -- bare min of 100 psi
anyways FWIW
http://www.boatfix.com/merc/bullet/97/97_25.PDF
anyways FWIW
the old Harleys said rering when front cyl was 110 and rear cyl was 90. they knew the rear cyl got hotter and burned up sooner. this merc bulletin ALSO says all cyls within 70% not 90% of highest. they are saying if you get a lil water and stick a few rings, the engine is still acceptable and not their problem...
What are you working on or looking at? There are some variables that can come into play. Static comp CR, Stock, rebuilt, how long has it sat, etc, As mentioned rule of thumb is within 10 % of each other. Doesn't mean if there all low it's ok. Build depending but 130-150 I'd think.
