502 MAG MPI - upgrade heads or stay stock???
Friends need advise on the following...
I recently purchased a pair of stock 502 MAG MPI's. Except for the Stainless Marine Exhaust everything else is stock.
Before purchasing these engines I was in the process of rebuilding my 454's (short blocks currently for sale on eBay) which I purchased a brand new set of Merlin Rectangular Port Iron heads as part of the build.
These are the specs;
310cc Rectangle port intake runners
119cc Open chambers
2.300" Stainless Intake valve
1.800" Inconel Exhaust valve
1.500" Dual valve springs 150lbs seat pressure approx. 400lbs open pressure
10' steel locks and retainers
I'm debating whether or not to install these heads on my 502's or sell them.
My questions are the following:
1) what gains can I expect in horsepower & torque?
2) would I have to make any adjustments to the ECU?
3) can I swap the stock heads with these heads with no further modifications?
Reality is my boat has been out of the water for 2 + years. Reason I purchased these 502's was because I could just drop them in. But before I do asking myself if it's worth it to install these heads or not.
Your thoughts!
Thanks!
119cc Open chambers
Your thoughts!
Thanks!
Griff makes a valid point here but you can bump those engines 100HP each w/ some head work, cam, and ECM tune. We had Tyler Crockett do that for us in a 454MAG years ago (also w/ Stainless Marine exhaust) and it really woke up the motor. To Griff's point and to address your question he modified the existing heads.
Griff / SecondWind...thanks for your responses. My 502's our ready to go as they are. The thought of any disassembly makes me cringe! Lol!
From research my boat (Pantera 28') will be at the 78-80 mph range with twin 502's as is. Fast enough for me just trying to take advantage of engines being out.
Any other quick mods any of you suggest?
I have 2 sets of Crane Roller Rockers from my 454 build. I understand thats an easy install. Worth it?
Change rockers? No need. One thing to consider. Steal the new valve springs off the new heads. Everybody who runs above 5000 rpm needs to replace their OEM valve springs. Ok, is valvesprings one word or 2? Now, if you did spring upgrade, a pair of ZZ502 cams for 200 bucks each would wake them up a bit. THEN you can put on the new rockers.
