496 HO Turbulators
Old 04-28-2017 | 05:24 PM
Default 496 HO Turbulators
Just had to show what 2 seasons can do to them. Not much left[ATTACH=CONFIG]566860[/ATTACH]
class6 is offline
Old 04-28-2017 | 09:04 PM
Wow
Mine are 15 years old and still look new.
underpsi68 is offline
Old 04-28-2017 | 09:22 PM
Originally Posted by underpsi68
Wow
I agree. Mine had 8 yrs run time when I pulled them. FL used boat. They looked new.
Ryan00TJ is offline
Old 04-28-2017 | 09:42 PM
To me it looks they might have been overheated.
Old 04-28-2017 | 11:47 PM
glassdave's Avatar
Neno the mind boggler
what would cause that? I have never seen that kinda wear before. Mine are ten years old and also still look new.
08 OPA High Points Champion
glassdave is offline
Old 04-29-2017 | 04:28 AM
Mine were 10 years old and looked like new when they were removed.
modvp is offline
Old 04-29-2017 | 05:30 AM
Electrolysis?
JRider is offline
Old 04-29-2017 | 05:35 AM
I think it was just a bad batch of stainless when these were made.
class6 is offline
Old 04-29-2017 | 02:26 PM
BUP
Merc uses tubular gaskets from a V6 thru a 6.2 as well just a different style - I have not seen one this bad period from any Merc app nor a 496 and I can honestly say a crap load of 496's have been thru my hands since 2001.
One would have to ask
is your engine stock ?
what type of fuels do run ?
What type of fuel additives do you use ?
where did you buy these gaskets ? and what brand ? Sierra or thru merc or thru Ebay ?
did you cut some of the flanging off making for a less restrictive exhaust passage ?
Surely looks like OVERHEATED to me as well - possible restricted water flow from the heat exchanger end cap gaskets - THIS IS MY GUESS - to be looked into if this was my app 4 sure.. Those end cap gaskets deform causing restricted water flow to the exhaust side as well.
Exhaust gases can be very corrosive as well. Why I asked about the fuel - and your engine set up - does your engine run overly rich ?
I am sure your boating is lake waters ? I am from the same area as you so I know the lakes very well.
BUP is offline
Old 04-29-2017 | 03:04 PM
BUP
what type of gaskets did you use for the top and bottom of the tabulators ?
BUP is offline
