Scorpion marine endurance clearance? >
Old 04-28-2017 | 10:19 PM
Default Scorpion marine endurance clearance?
Will scorpion marine endurance roller rockers fit under stock 502 mpi gen6 valve covers or is clearance needed?
27victory is offline
Old 04-29-2017 | 02:12 AM
Look down the page about 10-15 threads
Griff is offline
Old 04-30-2017 | 09:53 AM
Looks like that was referring to crane golds, the scorpion marine endurance says made to fit under stock gen 6 valve covers with no interference wondering if someone had actually ran them withoit clearance g anything. The corners on these rockers are rounded off.
Old 04-30-2017 | 12:08 PM
Kefurr's Avatar
I had to use a 1/2" spacer with my stock gen 6 valve covers
[ATTACH=CONFIG]566896[/ATTACH]
Kefurr is offline
Old 04-30-2017 | 12:38 PM
F-2 Speedy's Avatar
It maybe more about nut clearance than rocker arm, the poly locks that mercury used with the crane gold ones were a little shorter than the after market ones sold today, I have one set of the mercury poly locks if you need them.
F-2 Speedy is offline
Old 04-30-2017 | 01:27 PM
http://www.offshoreonly.com/forums/g...r-rockers.html
Griff is offline
