New Batteries Needed... Thanks Thief!! >
Old 04-30-2017 | 01:08 PM
RollWithIt's Avatar
Default New Batteries Needed... Thanks Thief!!
Have the pleasure of updating our batteries on the boat since somebody else obviously needed them more..... Any suggestions on what brand/type to go with? Not running a crazy stereo or mega lights on the boat. Was thinking about the Optima batteries but not sure if they would work with the charging system that is wired into the boat.
RollWithIt is offline
Old 04-30-2017 | 03:02 PM
That's a bummer, not many things worst then a thief.
I'm all for AGM's, have nothing but those in all water toy's, and to use them you need a charger that can be switched to AGM. Lead acid and AGM have different charge rates. Without the correct charger stick with lead acid and Interstate, Deka and the like
I won't even look at Optima, just not worth it.
Ones I do like and use are Lifeline and Odyssey, would also use Trojan. Good run of the mill AGM are the Duracell which can be had a wally world.
AllDodge is offline
Old 04-30-2017 | 04:48 PM
TYPHOON's Avatar
Optima blue top. I use them on all my boats.
TYPHOON is offline
Old 04-30-2017 | 08:14 PM
RollWithIt's Avatar
I switched to the Optima Red Top in my last truck when the batteries needed replaced. Never had any issues afterwards. I do know there is a different charge in regards to standard batteries and AGM style. I am sure the charger that is hooked up to the shore power on my boat is the Standard style as the boat is a 98 model. It will probably be cheaper and easier to get new good quality standard type batteries.
Old 05-01-2017 | 11:18 AM
Went with a Dekra - 1000 Crank Amp. So far so good.
In the past I would purchase the least expensive battery and just swap out every other year- This may not be the wisest financial decision I've made. Trying a little different approach -
I guess they are all good as long as the boat starts
3pointstar
3pointstar is offline
Old 05-01-2017 | 11:20 AM
Sears Die hard platinum. They are relabeled East Penn batteries, only ones still made in the USA and they are an AGM.
Optima moved manufacturing down to mexico, pure junk since then
kevinb230 is offline
Old 05-01-2017 | 11:38 AM
Odyssey, Northstar, or X2 Power (Batteries Plus version of Odyssey with identical specs). Optima don't come close to those.
PremierPOWER is offline
Old 05-02-2017 | 09:58 AM
RollWithIt's Avatar
I would like to get AGM batteries, but I will have to see if my charger will work with them. Otherwise that is just another expense...lol Gotta love boating.. lol
Old 05-02-2017 | 10:01 AM
Duracell AGM (Interstate's) or Optima Blue from what I've researched.
Tractionless is offline
