What are Lab props?
Old 05-03-2017 | 08:24 PM
Default What are Lab props?
What's up Fella's and Gals? What are Lab props and what's the difference?
Smokin_Joe is offline
Old 05-04-2017 | 04:36 AM
Do you mean labbed props? Labbed props are props that are fine tuned by someone like BBlades. You give them your horse power, speeds at certain RPMs, gear ratio and other things and they may add more or less cup and other magical things to the prop. This can give you more or less bow lift if needed. Night top speed among other things
Now if you really meant lab props than i don't know. I'm sure someone with more knowledge than the little bit I have will educate us shortly
Dahlilama is offline
Old 05-04-2017 | 05:30 AM
You answered my question. Thank you. I guess it's "Labbed"
Old 05-04-2017 | 06:12 AM
rak rua's Avatar
Bit stoopid here but don't they also thin down the blades slightly in some applications?
Thinner blade, finer cut through the water, lighter to spin but also not so strong if you like hitting things underwater.
RR
rak rua is offline
Old 05-04-2017 | 06:14 AM
dcb
Yes they thin the blades and true the props as well.
dcb is offline
Old 05-04-2017 | 06:18 AM
Here's a nice description from Mercury Racing on what they do to their Bravo 1 Labbed Finished props:
Mercury Racing blueprints and hand finishes the tried and true Bravo 1 propeller to give them their lab finished designation. These are balanced, thinned, and sharpened when compared to a stock Bravo 1 and feature a satin finish instead of the factory polish. They are generally faster and more efficient at top speed, but slip more in the midrange due to their thinner blade profile. The main advantage of a Mercury Lab Finished propeller over private modification prop shop finishes are the Mercury Lab propellers are extremely consistent and always provide the same performance results. This especially eases twin engine application propeller selection as Mercury Lab propellers are always matched pairs. hub kit NOT included.
SecondWind is offline
Old 05-04-2017 | 06:51 AM
rak rua's Avatar
Originally Posted by SecondWind
".................... and feature a satin finish instead of the factory polish................"
Using that as a segway to go off topic, is the satin finish a similar principle to that used on Speedmaster drives, Merc Racing outboards and similar which are painted with an 'orange peel' silver?
I'm assuming the textured finish helps to break up the water rather than stick to the high gloss Phantom Black.
Many years ago, a friend of mine sanded the Phantom Black off his Bravo and left it raw finish. Looked like some fancy ass racing unit but was still just a Bravo. He swore it was good for a couple of mph but I'm not so sure....
RR
rak rua is offline
Old 05-04-2017 | 07:05 AM
Indy's Avatar
Member #154
You need to be specific on what you want out of your prop, it will NOT increase performance across all ranges, at least that's my experience. If you spend little time WOT but mostly at a quick cruise you'll be disappointed if you don't have your prop tuned for that application, vice versa. You can also experience less bite when getting on plane if they grind some of the cup out.
Investigate first, it's expensive and might not be what you wanted. I wound up with a balanced and sharpened stock Bravo worked best for MY style of boating.
Indy is offline
Old 05-04-2017 | 09:04 AM
ask 100 people you will get 100 different answers!
pstorti is offline
Old 05-04-2017 | 04:45 PM
Its like a tire on a race car. The blades grab the water like rubber grabs the pavement. Each kind of tire serves a purpose but none do everything perfectly.
Each kind of prop will do something differently and make the boat better or worse in a certain enviroment.
hustlerguy is offline
