Why 50 weight oil?
Why 50 weight oil in a marine engine? The oil is thick and hard to pump, and takes longer to get back to the pan, why not 15/40? My motor desperately needs oil tstats (which it will get) but running that thick ass 20/50 knife edged my distributor gear. I would think there is a big parasitic loss just pumping it and there would be some substantial gains running 15/40. What advantage does the 50 weight have?
20/50. Bronze gear, very rarely made it over 130*. Judging by priming the pump with a 1/2" drill...it is definitely causing the knife edge.
With a bronze gear in a endurance application I'd also consider doing the Crane Cam tech tip of putting small groove in bottom of shaft housing to spray oil at the gear.
I'll try to find it in a bit so you can see. I Will also explain why to get rid of MSD's bottom o-ring if present.
