03 / 29 Fever Twin 6.2 MPI's - fuel issue port side motor
Fuel issue port side motor -- changed fuel pump / fuel pressure regulator still cannot get to 43 psi -- 40 psi only when throttling to 1500 / 200 rpm's pressure goes to 35 psi -- Starboard motor checked and fuel pressure is steady @ 43 psi -- note parts that were replace on port motor were not OEM Mercruiser -- any ideas would be greatly appreciated thanks Rich
Could also be the pick ups in the tank. I had some issues on my 6.2 boat and turned out the pickups were sucking air in the tank. Depending on the boat's age you might want to run new fuel lines between the tank and the cool fuel units as well. I think it cost me like $50 for new lines, well worth ruling out cheap easy stuff.
Look similar to this?
https://www.youtube.com/watch?v=QEa6kp5kOQg
If so, the fix was new pickups, fuel line and I needed a new fuel pressure regulator. I'd do the first two, then if having issues still, swap regulators.
Worth noting these were my 6.2s punched out to 383s and they were tuned to that fuel pressure. So it's lower than what you should expect. But still, same fuel system for the most part.
Hello again Captain ... yes looks very familiar ... so I am searching where and how on this boat to gain access to the pickup tubes in the fuel tank ... headed out to the garage and take another look ... any help or knowledge would be greatly appreciated thanks Rich
