Marine Application Serpentine belts
about 5 years ago you could find Dayco, Continental, Goodyear and so on cross reference for Serpentine belts and V belts. I can not find even one currently. Any links to the cross overs
Currently I am looking for a Volvo Penta 496 --- part number 3889126 And help there for starters.
At one time Volvo even cross you over to the Goodyear gatorback belts. I can not even find anything on that either.
about 5 years ago you could find Dayco, Continental, Goodyear and so on for cross reference for Serpentine belts and V belts. I can not find even one currently. Any links to the cross overs
The Gatorback brand/line was sold from Goodyear to Continental a year or two ago. You can find them under the Continental brand. BUT I have only had success ordering through mom&pop auto parts stores and online, NOT from the big parts houses/conglomerates.
A start:
http://www.thequietbelt.com/
6 rib and we measured it to roughly 915 / 916 mm in length --- on a tape measure it is 13 / 16 wide . I bought a dayco but it went on a bit easier meaning a hair bigger in length. I think it measured to 918 or 920 mm in length.
the dayco sits a tiny hair taller in between the pulley's, here is the part number I bought --- Dayco 5060920 6PK2338. But it is new vs a used belt.
As I said it did go on a bit easier as well so I think a couple mm shorter would be better after some belt wear in. The engine does have a tension idler for the set up.
I believe this belt fits a Ford 4,6 L in the auto world.
Napa/Gates Part # 25-060355 is 918mm length 6 Rib ... Next Shortest belt in the 6 rib is 894 mm.
OH thanks that was fast I did order a gates at O Reilly's but do not know the number of it. Its in now.
Do you own a NAPA store, if I recall someone did up here, so I am thinking it was you ? Thanks for looking that up and your time
Yup, It only took me about 2 seconds to get that info for you lol. 7/8" is a considerable difference when it come to a belt.
