Marine kinetics custom cam 10hrs of use >
Old 05-11-2017 | 07:47 PM
Default Marine kinetics custom cam 10hrs of use
Gen 6 hyd roller cam specs by marine kinetics 233int 237ext duration .646 .638 lift on 114lsa ran it for about 10hrs was 595.00 new i will let it go for 350.00
Jamsf1984 is offline
Old 05-11-2017 | 08:01 PM
[ATTACH=CONFIG]567340[/ATTACH]
Attached Thumbnails Marine kinetics custom cam 10hrs of use-threadugly8wy.gif
phragle is offline
Old 05-11-2017 | 08:34 PM
seafordguy's Avatar
Haha - I need to check my cam card but that sounds like the same "custom" cam he cut for me.....
Good luck with sale
seafordguy is offline
Old 05-11-2017 | 08:52 PM
SB
Was in a HP500. He is building a 540. See here: http://www.offshoreonly.com/forums/g...ml#post4553362
SB is online now
Old 05-11-2017 | 10:06 PM
595 for a cam? Thats a good deal.
Crane gets 418.00 , comp 410, jones cams around 400, for billet custom ground hyd roller cams with iron gear.
Not bad though, im sure his leadtime is much faster than 4 days to get it. Sometimes its worth paying more when you need it faster.
MILD THUNDER is offline
Old 05-11-2017 | 11:33 PM
are you sure about the 595 price,i have bought my share of cam,s from mk and i believe i pay under 450 and that includes a melonized dist gear.
mike tkach is offline
Old 05-11-2017 | 11:57 PM
It lasted 10 hrs? I think I have one from him that lasted about 20 hrs. He sells these cams as the latest custom grinds while criticizing all other cam companies as old technology. It is not unusual to find the specs of one of custom grinds in the shelf cam catalogs from Crane and Comp Cams. A real con artist who tries to dazzle you with technical terms he has only surface level knowledge about.
bultmand is offline
Old 05-12-2017 | 12:26 AM
Yes i am rebuilding my hp500 into a 540 the motor was fine i just wanted more hp, and i know this doesnt help me selling it but oh well i definitely was not pleased with mk this cam was supposed to make more power i lost 1 to 2 mph with it and then he blamed everything else on why it didnt but i figured if anyone can use the specs it has for there combo then great and yes it was 595 i should have called comp or crane , isky sorry about the bashing its just my opinion thanks
Old 05-12-2017 | 06:11 AM
595.00....? Oh, he got the "latest and greatest" custom ground billet(and polished) high lift 3/4 race cam....they are new to the market.
kreed is offline
Old 05-12-2017 | 07:08 AM
https://www.youtube.com/watch?v=rY0WxgSXdEE
Eliminated572 is offline
