18-364 - BBC MARINE POWER PAN + 18-365 pickup
$375
2 available
This extra high capacity “T” sump is for standard Big Block Chevys with 2 piece rear seals. The 8" deep by 14" long by 14" wide sump holds 10 quarts of oil (Pan Only). The pan is angled in the front for improved drain back & is notched for a sea pump. Note: These pans have been REDESIGNED to clear O.E.M. marine starters with a 168 tooth flywheel. This pan requires our 18-365 pickup.
Construction
* Six Trap Door Baffles
* Oil Recovery Pouch
* Crank Scraper
* Bolt In Slosh Baffle
* Built In Louvered Windage Tray
* Three 1/2" NPT Bungs
* Provision For our Pan Mounted Dipstick
* Powder Coating & Brass Plugs For Corrosion
Protection
https://www.cantonracingproducts.com...ion&key=18-364
2 available
Construction
* Crank Scraper
Protection
