Merc 496HO sudden shutoff! >
Old 05-16-2017 | 05:14 PM
Question Merc 496HO sudden shutoff!
Was out for the Tickfaw 200 last weekend and my motor just shut off all of the sudden... there were two or three beeps, and then nothing. It would turn over, so it wasn't the battery. Seemed like either no fire or no fuel. Had a full tank of non-ethanol Premium. I suspect either a burnt fuse controlling the EFI or the fuel pump. No popping, stuttering or intermittent on-off. Haven't pulled the cover off yet... will try this weekend.
Any ideas???
BerZirk is offline
Old 05-16-2017 | 06:05 PM
BUP
Crank Position sensor especially if you have NO TACH SIGNAL
next fuel pump(s) working - check for fuel pressure with key on and while cranking.
Scan engine for codes and available power % - if available power shows 100 percent you are not in any form of guardian mode.
BUP is offline
Old 05-17-2017 | 05:25 PM
Any ideas???
Kill switch went bad
Edit: BTW if this is a stock 496 you don't need premium fuel
AllDodge is offline
